IPC-7352 strange evolutions |
sot23
Thanks(1)
Topic: IPC-7352 strange evolutionsPosted: 4 hours 18 minutes ago at 8:23am |
Hello, my team recently purchased the IPC-7352 released in 2023 and I am currently in the process of studying it to decide whether we should make it our new standard for footprints creation or not. For the moment I must admit that I am not thrilled by what I have read. Some exemples :
My question : what do you all think about 7352 ? I would be very interested in your opinion specifically, Tom H, as I know you are very much involved in the IPC talks (thanks for all your work on that by the way). Is it a good upgrade to 7351B ? Honestly I was hoping for more. But maybe I am a bit to difficult... Sorry if my English is not perfect, as it is not my primary language.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5966 |
Posted: 3 hours 45 minutes ago at 8:56am |
IPC-7351B and IPC-7352 are identical for Surface Mount. No change except the pad stack naming convention added a double 'rr' for Rounded Rectangle pad shape.
IPC-7352 introduced Through-hole technology, but most of the information was extracted from IPC-2221 & IPC-2222. The main thing that was added was the Through-hole land pattern naming convention which we created in 2008 but shelved until 2023. The IPC-735x series misses the mark in several areas. - Solder joint goals 'one size fits all' doesn't produce the best assembly attachment and it doesn't adhere to IPC J-STD-001. Also, the values between density levels is too robust. Most is too Most and Least is too Least. - The naming convention puts the 'pin qty' at the end of the footprint name. This was changed in the IPC-7351C standard that was unanimously approved by the land pattern committee but never got released. - The Zero Component Rotation differs from the standard they replaced - IPC-SM-782 Related posts: |
