  New Posts New Posts RSS Feed - IPC-7351C Pin 1 Polarity Marking
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2015 at 5:33pm
Great! I'm glad Jeff acknowledged the bug and he will fix it for the V2015.08 release.
Thanks for pointing this issue out. We prefer bug free software.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2015 at 9:49pm
Steve, please download/try the new pre-release from here - www.PCBLibraries.com/downloads
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2015 at 10:44pm
I have been using .08 since early afternoon.  It has the same problems.  Has it changed since 5 pm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2015 at 10:52pm
Yes, a new build was posted about an hour ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2015 at 12:58pm
The 08 version seems now to let me save the silkscreen drafting preferences.  However, it does not display them consistently.  Sometimes they are blanked out even when the preferences file is saved, loaded, and editor is restarted.
FYI: Another bug that Jeff took note of for me is that when you are in the editor, you have the ability to set several drafting items and see them as they would appear when you click OK.  However, when you build the part(s), the user preferences for drafting override anything that had been entered, and you lose that work.  Apparently this is because you are not allowed to edit items under the drafting tab - even though they are not grayed out..... a royal garden path.
What we need is a way to override the defaults part-by-part and build them the way they look while editing them.  There are exceptions to every rule.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 8:41am
All of the issues that were reported should be fixed in a new V2015.08 pre-release uploaded today.
