IPC-7351C Pin 1 Polarity Marking |
Page 12> |
SteveD
Joined: 30 Oct 2013 Location: San Diego Status: Offline Points: 240 |
Thanks(1)
Topic: IPC-7351C Pin 1 Polarity MarkingPosted: 08 Jan 2015 at 4:38pm |
When the new version 6 comes along matching the new way of doing IPC pin 1 designators, does that mean that polarized cap, diode, etc silkscreen will be mirrored? E.g. pin 1 on the left, silkscreen opening on the left now instead of on the right?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5985 |
Thanks(1)
Posted: 08 Jan 2015 at 6:35pm |
Great question! There are 3 different silkscreen polarity markers:
When the terminal leads extend beyond the body of the component package the silkscreen polarity marker is a Line that runs the full length of the pad and is visible after assembly. When the terminal leads are under the component package (BGA, LGA, CGA, PQFN, PSON, DFN, etc.) the silkscreen polarity is removal of silkscreen. This is because the placement courtyard on "Bottom Only" terminals hugs the component package and there is no room to place a visible silkscreen polarity marker that is located inside the placement courtyard (not enough room). Note: the full silkscreen outline component boundary is shown and where the silkscreen is missing, that's pin 1. Intended for high density part placement. The Chip and Molded Body 2-pin component the silkscreen polarity wraps around pin 1 (or Cathode) and is visible after assembly. Where non-polarized Chip and Molded Body only have parallel side component silkscreen lines that map to the package length. |
SteveD
Thanks(1)
Posted: 02 Feb 2015 at 5:51pm |
Is there ever any real need for a pin 1 dot any more?
If not, why is it there in UserDefaults?
Thanks(1)
Posted: 02 Feb 2015 at 7:42pm |
The Silkscreen Pin 1 Dot is only there because some people asked for it. You can turn the Silkscreen Dot off in the "Drafting > Silkscreen" preferences by changing the value to 0 (zero). This is applicable for any outline that you don't want. |
SteveD
Thanks(1)
Posted: 02 Feb 2015 at 9:46pm |
Can I turn it off just for the component I am currently editing, or will the user defaults override what I do and put it back in while I build? Generally speaking our preference is for ICs and connectors to have a dot, but passive components likes R's and C's and I's not to.
BUT we do not want to have different user defaults for the special cases. We want just one user default file for the whole library of all part types and the ability to override the default for any particular footprint instance. Make sense?
jameshead
Joined: 20 Mar 2012 Location: Oxfordshire, UK Status: Offline Points: 576 |
Thanks(1)
Posted: 03 Feb 2015 at 5:32am |
Our CAD tool, Pulsonix, has an automatic feature that clips the silkscreen automatically over solder mask clearances on the CAM output to prevent silkscreen over pads.
I only raise this because on every PCB Libraries footprint that I've generated since they added back in the silkscreen "dot" I've found the majority of dots on any board are automatically "clipped". Since you then have a PCB with dots on some components but maybe not on other components of the same type in a more dense area it doesn't make sense to use them as an after-assembly aide for checking. The assembler should never be using the silkscreen to generate assembly data prior to assembly anyway - I make that clear in all my documentation. That's what the assembly drawing is for. Just my tuppence half-pennies worth. |
SteveD
Thanks(1)
Posted: 03 Feb 2015 at 1:18pm |
Our assemblers are students and usually jump right in without an assembly drawing soldering by hand. They know what is what. But they may have forgot which way is which. The dot will help, and the new IPC way is harder to see.
SteveD
Thanks(1)
Posted: 03 Feb 2015 at 2:33pm |
There is an unanswered question above for you Tom - 5th post in this thread. Also, now when I create a new user preferences file with the preference of a 0.0 pin 1, then close PCBLE, then open PCBLE, and look at the preferences, its back to 0.40. It will not go away, although it remembers my user suffix choice. There seems to be no way to create a UserPreferences.dat with no pin 1 on the silkscreen. Can you hear me screaming? |
Thanks(1)
Posted: 03 Feb 2015 at 2:37pm |
You can turn off any outline in User Preferences by changing the value to 0 (zero). In the V2015.08 pre-release there is also a provision for separation of Silkscreen and Pin 1 Dot. i.e.: You can now turn of the Silkscreen Outline and keep the the Dot (they are now independent of each other). |
SteveD
Thanks(1)
Posted: 03 Feb 2015 at 4:43pm |
I talked to Jeff, and it is confirmed that there is a bug saving silkscreen settings in the User Preferences file.
Page 12> |
