  New Posts New Posts RSS Feed - IPC-7351 SMD & PTH Reference Calculators
dfournier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfournier Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 12:09am
Hello guys,
I start to create footprints with IPC-7351.
Could you tell me what are Thermal ID and Thermal OD for PTH?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 7:32am
Thermal Relief is for all PTH pins that connect to a Plane.
A PTH lead with a direct connection to a GND or VCC Plane can have a cold solder joint because the plane can dissipate all the heat from that connection.
ID = Inside Diameter of Plane Pad
OD = Outside Diameter of Plane Pad
The thermal ID & OD are connected with Spokes from the pad to the copper plane.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfournier Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 5:24am
Hello Tom,
Thank you for informations.
Does IPC define Thermal ID and OD? I don't find explanation that define these diameters.
I use CADSTAR software and Thermal ID and OD are differently defined.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 7:35am
IPC-2221 and IPC-2222 are the only documents with through-hole pad stack info.
IPC-7351C is stalled in committee and will not be released for another year or so.
Every CAD tool defines Thermal Relief patterns differently.
Library Expert has over 100,000 users worldwide and no one has ever complained about this issue in the past 6 years. We use best practice math that we have tested and tried in a CAD tool library since 1982.
stanleycayochok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanleycayochok Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 9:14pm
There is a difference on the Smax[RMS] formula between IPC7351 and from the "PCB Library Expert SMD Reference Calculator.xlsx"
IPC7351 RMS Smax formula:
Smax[RMS] = Smin + Stol[RMS]
Library Expert RMS Smax formula:
New Smax = Smax - (Stol -Stol[RMS])/2
Both will result in a different output value.
May I know why Library Expert used such formula?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 11:10am
I believe the formula you're referring to (Smin + Stol[RMS]) dates back to the IPC-SM-782 document from 1993.  IPC revised this about 2005.
Please refer to IPC-7351B section 3.1.1 (should be page 11) shown as follows.
This example is demonstrated in our free SMD Reference Calculator for Excel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanleycayochok Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2021 at 5:17am
Hi Jeff,
There is no image on your post.
I was referring to this Smax[RMS] formula in the 2005 IPC7351, please refer to attached image:
In the "SMD Reference Calculator for Excel" the formula is this:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2021 at 11:18am
You should try to get a more recent copy of IPC7351.
What follows is a direct quote from IPC-7351B, June 2010. Note the line for Smax.
(All the values in the Excel Reference Calculator match the example given in that document, allowing for rounding).
"Therefore, the calculations for ‘‘S’’ minimum and maximum dimensions are as follows:
Smin = Lmin - 2Tmax = 5.8 mm - 2 (1.27 mm) = 3.26 mm
Smax = Lmax - 2Tmin= 6.2 mm - 2 (0.4 mm) = 5.40 mm
Stol = Smax - Smin = 5.4 mm - 3.26 mm = 2.14 mm"
Section 3.4.1 discusses the reason for creating New_Smax.
New_Smax is ultimately used to produce Gmin.  Not Smax.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanleycayochok Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2021 at 12:47am
Will definitely get the latest version.
Thank you Jeff for the detailed explanation.
Aaronbat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaronbat Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 4:46pm
I have the calculator but I'm new reviewing this kind of stuff, from where I can get the information is question on the fields:
  • Fabrication Tolerance
  • Placement Tolerance
  • Toe Goal
  • Heel Goal
  • Side Goal
  • Place Round
  • Size Round
Some of them I don't know what it means. Cry
