IPC-7351 SMD & PTH Reference Calculators |
Page <123> |
dfournier
Posted: 09 Jul 2018 at 12:09am |
Hello guys, I start to create footprints with IPC-7351. Could you tell me what are Thermal ID and Thermal OD for PTH?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6074 |
Thanks(1)
Posted: 09 Jul 2018 at 7:32am |
Thermal Relief is for all PTH pins that connect to a Plane. A PTH lead with a direct connection to a GND or VCC Plane can have a cold solder joint because the plane can dissipate all the heat from that connection. OD = Outside Diameter of Plane Pad The thermal ID & OD are connected with Spokes from the pad to the copper plane. ![]() |
dfournier
Posted: 10 Jul 2018 at 5:24am |
Hello Tom, Thank you for informations. Does IPC define Thermal ID and OD? I don't find explanation that define these diameters. I use CADSTAR software and Thermal ID and OD are differently defined. |
Posted: 10 Jul 2018 at 7:35am |
IPC-2221 and IPC-2222 are the only documents with through-hole pad stack info.
IPC-7351C is stalled in committee and will not be released for another year or so. Every CAD tool defines Thermal Relief patterns differently. Library Expert has over 100,000 users worldwide and no one has ever complained about this issue in the past 6 years. We use best practice math that we have tested and tried in a CAD tool library since 1982. |
stanleycayochok
Posted: 15 Feb 2021 at 9:14pm |
There is a difference on the Smax[RMS] formula between IPC7351 and from the "PCB Library Expert SMD Reference Calculator.xlsx"
IPC7351 RMS Smax formula: Smax[RMS] = Smin + Stol[RMS] Library Expert RMS Smax formula: New Smax = Smax - (Stol -Stol[RMS])/2 Both will result in a different output value. May I know why Library Expert used such formula? |
Jeff.M
Joined: 16 May 2012 Location: San Diego Status: Offline Points: 501 |
Posted: 16 Feb 2021 at 11:10am |
I believe the formula you're referring to (Smin + Stol[RMS]) dates back to the IPC-SM-782 document from 1993. IPC revised this about 2005.
Please refer to IPC-7351B section 3.1.1 (should be page 11) shown as follows. This example is demonstrated in our free SMD Reference Calculator for Excel. |
stanleycayochok
Posted: 25 Feb 2021 at 5:17am |
Hi Jeff,
There is no image on your post. I was referring to this Smax[RMS] formula in the 2005 IPC7351, please refer to attached image: ![]() In the "SMD Reference Calculator for Excel" the formula is this: New Smax = Smax - (Stol -Stol[RMS])/2 ![]() |
Jeff.M
Posted: 25 Feb 2021 at 11:18am |
You should try to get a more recent copy of IPC7351.
What follows is a direct quote from IPC-7351B, June 2010. Note the line for Smax. (All the values in the Excel Reference Calculator match the example given in that document, allowing for rounding). "Therefore, the calculations for ‘‘S’’ minimum and maximum dimensions are as follows: Smin = Lmin - 2Tmax = 5.8 mm - 2 (1.27 mm) = 3.26 mm Smax = Lmax - 2Tmin= 6.2 mm - 2 (0.4 mm) = 5.40 mm Stol = Smax - Smin = 5.4 mm - 3.26 mm = 2.14 mm" Section 3.4.1 discusses the reason for creating New_Smax. New_Smax is ultimately used to produce Gmin. Not Smax. |
stanleycayochok
Posted: 26 Feb 2021 at 12:47am |
Will definitely get the latest version. Thank you Jeff for the detailed explanation.
Aaronbat
Posted: 12 May 2023 at 4:46pm |
I have the calculator but I'm new reviewing this kind of stuff, from where I can get the information is question on the fields:
Some of them I don't know what it means.
Page <123> |
