  New Posts New Posts RSS Feed - IPC-7251
IPC-7251
drj-bbe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7251
    Posted: 25 Nov 2015 at 2:33am
Hi all:
I cannot find IPC-7251 in IPC website, it haven't released?
What is the standard for through hole land calculation in Library Expert?
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 5:48am
The IPC Land Pattern committee decided a year ago to merge IPC-7251 for through-hole into the new IPC-7351C.
You can download several documents here - http://www.pcblibraries.com/downloads
  • What's New in IPC-7351C
  • Surface Mount Component Families
  • Through-hole Component Families
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 7:45pm
Thank you very much. I have other questions below:
The calculation formula below for pad diameter is different with IPC-2221B 9.1.1, how to set "pad to hole ratio" and "minimum annular ring"?
The calculation of pad diameter in IPC-7351C will not consider "Standard fabrication allowance" which in IPC-2221B Table 9.1, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 8:55pm
Set all the Through-hole user preferences -
Preferences > Terminals > Through-hole
The current default settings are from IPC-2221 but will also be in IPC-7351C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 12:59am
Thanks, but I still confused on below two calculation method for a pad:
IPC-2221B calculation formula is:
Land size, minimum = Hole size + 2*Min. annular ring(Min 0.05mm) + fabrication allowance
IPC-7351C calculation formula will be:
Pad diameter = Hole size + 2*Min. annular ring(Min 0.2mm), or = Hole size * pad-to-hole-ratio, whichever is larger.
But calculated result will be different between above two calculation method, IPC-7351C defined a proportional annular ring, IPC-2221B defined same size annular ring even though hole size go up, right?
This is for minimum pad design, the annular ring seems smaller than normal, is there suggestion for normal pad size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 10:44am
Library Expert only uses "Hole Over Lead" from IPC. Everything else uses the PTH Reference Calculator located here -
http://www.pcblibraries.com/forum/ipc7351-smd-pth-reference-calculators_topic785.html
