Forum Home Forum Home > Libraries > Schematic Symbols > OrCAD Capture
  New Posts New Posts RSS Feed - IPC naming convention for schematic symbols?
Randy Clemmons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Clemmons Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 8:24pm
JohnH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2013 at 12:45am
As mentioned it very much depends on the system.
In general I prefer systems which can support the "one to many" approach where a symbol can map to multiple footprints. These systems are typically supported by a database.
For symbols which incorporate the pin number mapping I use this convention:
[Prefix]_[item]_[Variant]
For an IC the prefix would be IC and the item would be the manufacturers part number with RoHS and packaging codes removed.
For other parts such as Transistors the prefix would be Transistor the item could be NPN and the variant would be the pin mapping in the order of pin e.g.
Transistor_NPN_ebc
This is an NPN transistor with emitter pin 1, base pin 2 and collector pin 3
This page was generated in 0.532 seconds.
