  New Posts New Posts RSS Feed - IPC Abbreviations
IPC Abbreviations
AGONZ67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Topic: IPC Abbreviations
    Posted: 12 Jun 2019 at 3:16pm
Do we still default to ASME Y14.38 for abbreviations? Is there an IPC spec that deals specifically with electrical components/abbreviations?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:21pm
The IPC-T-50 is Terms and Definitions. It gets updated every couple of years.
Are you referring to Reference Designators?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 4:21pm
No I am actually referring to abbreviations used in the description of components. In PADS there is an attribute field in the part type named "description". Is there an IPC document that governs what abbreviations are authorized? For example Metal Film is often abbreviated MTL FLM, but ASMEY14.38 uses FLM as an abbreviation for flame. Does IPC have it's own comprehensive abbreviation guide tailored exclusively for PCB abbreviations? I would think IPC and electonics has evolved to the point of no longer relying on a mechanical specification?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 8:13am
IPC does not, but PCB Libraries does.
Look in this folder -
C:\Program Files (x86)\PCB Libraries\Library Expert 2019\Documents
  • Library Expert Surface Mount Families.pdf
  • Library Expert Through-hole Families.pdf
They are listed starting at the Molded Body component family.
The Chips are -
  • ANTC - Antenna
  • CAPC - Capacitor
  • CAPPC - Capacitor, Polarized
  • DIOC - Diode
  • DIONC - Diode, Non-Polarized
  • BEADC - Ferritte Bead
  • FLTRC - Filter
  • FUSC - Fuse
  • INDC - Inductor
  • LEDC - LED
  • RESC - Resistor
  • THRMC- Thermistor
  • VARC - Varistor
