  New Posts New Posts RSS Feed - Import part with non-standard pads (Altium)
toshas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Topic: Import part with non-standard pads (Altium)
    Posted: 27 Jul 2019 at 4:08am
Hi!
I have some troubles during import EBYTE E73-2G4M04S1B in Altium.
Picture is attached.
Rectangular pads are ok, solder mask expansion is determined by rules.
Non-standard pads (15,16) has solder mask dimensions exactly same as copper pad (it is imported in Altium as solid copper region).
So manual edition of several pads is needed.
Is any workaround for this issue ?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 3:29pm
In the Library Expert Altium Translator UI, turn on the check box for "Use Mask Expansion Rules".
Also, in FP Designer you can edit the pad stacks in the Library Manager and swell the solder mask any size you want and save to FPX.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2019 at 5:32am
Hi!
Picture above was done with enabled check box for "Use Mask Expansion Rules".
Then I edited pad stack in the Library Manager so solder mask will always have 1mils expansion.
After export it works (regardless of "Use Mask" check box status) as expected.
Thanks!
