  New Posts New Posts RSS Feed - Illegal Character in Library Fields
tgrodnicki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tgrodnicki Quote  Post ReplyReply Direct Link To This Post Topic: Illegal Character in Library Fields
    Posted: 30 Aug 2023 at 5:51am
Characters "ó" (Latin Small Letter O with Acute) or "Ó" (Latin Capital Letter O with Acute) are not allowed in library fields.
Other Polish diacritics are acceptable.
Footprint Expert 23 Enterprise Edition 23.11, 8/25/2023
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 7:49am
The FPX file is ASCII format.
Any "Symbol" is illegal in an ASCII database. People copy/paste data from a PDF file into a FPX cell and then the database becomes corrupt.
You can open the FPX file in Excel spreadsheet and locate the damage easily and remove it. But to get the Excel data back to FPX you must copy/paste the Excel rows and columns into an ASCII text editor like Notepad and then save the file back to .fpx format.
Common illegal Symbols are - ™ ©  ±  °  µ  ®    Ã
Post Options Post Options   Thanks (0) Thanks(0)   Quote tgrodnicki Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 10:42pm
I thought that since the 2020 database was accepting such characters, the current behavior was a bug.
In this case, the program should not allow the input of characters with ASCII codes outside the range 20-127.
If the database data format will be changed in the future, you can try to support Unicode encoding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 4:03pm
Error checking added to library paste and edit operations that will flag and fix any illegal characters with ASCII codes of less than 32 or greater than 126.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 7:44am
Download and install V23.13 to get this update - www.pcblibraries.com/downloads
This page was generated in 0.593 seconds.
