  New Posts New Posts RSS Feed - how to use the SMD reference calculator?
fishoutofwater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fishoutofwater Quote  Post ReplyReply Direct Link To This Post Topic: how to use the SMD reference calculator?
    Posted: 04 Nov 2015 at 1:08pm
This is probably a very silly question, but how do I use the SMD reference calculator?
Is L/S/T/W information gathered from the package data sheet, and C/X/Y the recommended footprint outlines?
Thank you for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2015 at 9:24am
The purpose of the reference calculator is to help understanding the IPC land pattern calculation as set forth in the IPC-7351 publication.  L, S, T and W are terminal dimensions provided by the component manufacturer.  C, X and Y are the dimensions of the calculated land pattern.
You should refer to chapter 3 of the publication for a full explanation.
