  New Posts New Posts RSS Feed - How to Extract Back Dimension From FPX File
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: How to Extract Back Dimension From FPX File
    Posted: 6 hours 50 minutes ago at 5:15am
How to extract back dimension from FPX file in Excel spreadsheet or Text format instead open in Footprint Expert and get one by one.
For example:
FPX built by chip module, need get values for its parameter
Amax Dmin Dmax Emin Emax Lmin Lmax L1min L1max
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 36 minutes ago at 8:29am
There are 2 options for extracting data.
The 'Print' feature is in in both the Calculator and FP Designer.
The import/export to CSV file is in FP Designer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 36 minutes ago at 8:29am
This must be manually transcribed from the FPE program.
To automate as requested, a program would have to be written to extract the data from an fpx file which would compromise the IP contained in those files.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 55 minutes ago at 10:10am
For designer tab:please give more details how and steps
For calculator how to make like this instead of manually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 46 minutes ago at 11:19am
The only data exported to an Excel CSV file are the pin coordinates.
There is no feature for exporting all the footprint dimensions to CSV file format.
We have no plans to create this feature.
You can use the 'Print' feature to create a .PDF file with all the coordinates.
