How to Extract Back Dimension From FPX File |
| Author | |||||||||
m.elsayed
Topic: How to Extract Back Dimension From FPX FilePosted: 4 hours 1 minutes ago at 5:15am |
How to extract back dimension from FPX file in Excel spreadsheet or Text format instead open in Footprint Expert and get one by one.
For example: FPX built by chip module, need get values for its parameter
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5980 |
Posted: 47 minutes ago at 8:29am |
There are 2 options for extracting data.
The 'Print' feature is in in both the Calculator and FP Designer. The import/export to CSV file is in FP Designer. |
Jeff.M
Joined: 16 May 2012 Location: San Diego Status: Offline Points: 494 |
This must be manually transcribed from the FPE program. To automate as requested, a program would have to be written to extract the data from an fpx file which would compromise the IP contained in those files. |
