  New Posts New Posts RSS Feed - How To Create a Footprint (Land Pattern)
mahadevan02 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mahadevan02 Quote  Post ReplyReply Direct Link To This Post Topic: How To Create a Footprint (Land Pattern)
    Posted: 27 Oct 2013 at 5:49am
Dear Sir/Madam
How do I create a land pattern footprint using a datasheet? Some doubts of Allegro tools.
Please any help me as I am not familiar with Allegro CAD tool land pattern using datasheet.
With Regards,
A. Mahadevan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2013 at 7:38am
Hiep Pham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hiep Pham Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 6:08pm
How do I create a footprint for a 32-pin socket drawing (32L-OPTP-5X5-0 5mm).
B/R,
Hiep Pham
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 6:09pm
Do you have a web-link to the physical mfr. datasheet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hiep Pham Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 6:30pm
No I don't have a web-link. Please help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 7:03pm
Do you have a mfr. datasheet or a mfr. part number? Who is the component mfr.?
You cannot create a footprint without component dimensions.
Here is what I get if I do a Google search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hiep Pham Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 3:11pm
Please see the attached zip file for socket drawing. Please help to show me how to create a footprint for this socket drawing.
Hiep
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 6:39pm
You have to create this library part in Footprint Designer. This is a QFN socket.
Here is the footprint dimensions. Everything you need is here to create this library part in 15 minutes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hiep Pham Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2013 at 5:14pm
Where can I get footprint designer software? If I buy PCB library expert software from this website, Will I able to create this footprint from generic template?
Hiep
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2013 at 6:41pm
Yes, if you purchase the "PCB Library Expert" you will get 4 features that the LE Lite does not have -
  1. The Librarian gives you the ability to save all of your component dimensions and part attributes in neutral FPX format for your library management.
  2. User and Default Preferences allows you to globally change all of your drafting and solder joint goal settings.
  3. Footprint Designer allows you to create non-standard package footprints with unique pad stacks and pad placement. And you can save this data in your FPX file library.
  4. Access to "Parts on Demand" (POD) which currently has over 170,000 component mfr. part numbers and component dimensions available in FPX file format. The database of components is growing fast and will eventually have millions of component mfr. part numbers.
Watch this FP Designer video for creating complex footpints, click here
