  New Posts New Posts RSS Feed - How Do You Modify a Part That You Already Imported
bleslie82 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bleslie82 Quote  Post ReplyReply Direct Link To This Post Topic: How Do You Modify a Part That You Already Imported
    Posted: 16 Jan 2014 at 8:02pm
I made a BGA part and would like to update the padstack on it.
The part is already imported into a library.
If I show the footprint and then modify it, how do I get the changes to update.
Clicking on import footprint again just adds another row with the same footprint name, but the changes are not there.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2014 at 8:09pm
Are you trying to -
  • Import a library into your CAD tool?
  • Import the updated component dimensions into a FPX file?
  • Did you use the Calculator to input the component dimensions?
  • Did you use the Footprint Designer to enter the mfr. recommended footprint dimensions?
Let us know your situation.
Post Options Post Options   Thanks (1) Thanks(1)   Quote bleslie82 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 6:51pm
Tom,
I made a BGA and imported it into an .fpx library.
I now want to change the pad to increase the solder mask opening and replace the part that is in the .fpx library.
Here are the steps that I was trying to use.
  1. Select the part in the fpx library
  2. Edit padstack (footprint graphics get updated)
  3. Try to import the changed part back into the fpx library
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 9:13pm
I still don't know if you used the IPC Calculator or FP Designer to create the BGA footprint.
It sounds to me like you used FP Designer, so it must be a non-standard BGA. Is this true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2014 at 8:08am
Regardless if you created the BGA using the IPC Calculator or the Footprint Designer, they both get updated into your FPX library that same way.
Open your FPX library and select the Gray Button (ITEM 1) to the left of the Footprint name to highlight the entire row. Then select the "Insert Part" icon (ITEM 2) in the toolbar and it will automatically update your FPX library line item with your Component Dimensional changes or your FP Designer mfr. recommended footprint changes -
You will get prompted to "Update Selected Item" -
Post Options Post Options   Thanks (1) Thanks(1)   Quote bleslie82 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2014 at 11:40am
Tom,
Thanks that is exactly what I was looking for!
