  New Posts New Posts RSS Feed - Header Part Creation - Pads Have 0.02mm Clearance
Smooth.Sailing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smooth.Sailing Quote  Post ReplyReply Direct Link To This Post Topic: Header Part Creation - Pads Have 0.02mm Clearance
    Posted: 12 Dec 2013 at 12:02am
I created a 1x2 Header, Vertical.  Used a pitch of 1.27 mm and a square post of 0.40 mm.  The result was a hole of .75 mm and a pad of 1.25 mm.  Should a 0.02 mm clearance beween pads generate a warning?
The manufacture recommends a hole of .70 mm and does not recommend an annular ring.
Clearly this can all be rectified by using the manufacture setting to enter something that will work.  However, given that you have this type of part as an auto feature, I thought you might like to know these results.
Also should silkscreens overlaying pads generate a warning?
 I am a newbie.  I apologize if I have missed something.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2013 at 7:38am
Only the Surface Mount component families have pad to pad trimming and warnings. The SMT calculator can Trim Pads to meet the rules and provide a warning.
You cannot trim through-hole pads because you would remove annular ring.
This page was generated in 0.223 seconds.
