HARWIN M20-7812045 Size of Pin 1 Marking |
toshas
Topic: HARWIN M20-7812045 Size of Pin 1 MarkingPosted: 31 Aug 2019 at 9:14am |
Hi! I tried to change size of pin1 mark in HARWIN M20-7812045 footprint with no success. Thanks! |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6031 |
Posted: 31 Aug 2019 at 9:59am |
For all FP Designer connectors, do this...
Right Mouse Button (RMB) and select "Shapes". Double Click on the Polarity Marker. A dialog box should appear, but if the Polarity Marker is selected just RMB and select "Properties" Then select any new shape, change any layer, change the size and location. Note: if the Polarity Marker is filled, unselect the Filled button after you change the size and then reselect the Filled button to refill the shape. Then Apply and exit. |
toshas
Posted: 31 Aug 2019 at 10:33am |
Got it! Thanks!
