Gull Wing Heel Size Changes In Least Mode |
lalexman
Topic: Gull Wing Heel Size Changes In Least ModePosted: 11 Oct 2013 at 12:37pm |
In creating a .5MM 8 Pin SOP in least mode. The heel in least mode is .25MM. When I change the pad length from .39MM to .40MM the heel value changes to .05MM.
I have the trim set to 0.00
Attached is a video.uploads/545/SOP_LEAST.zip
Jeff.M
Joined: 16 May 2012 Location: San Diego Status: Offline Points: 497 |
Posted: 11 Oct 2013 at 2:29pm |
Thanks for the video...it really helps in this case.
Note in your video the terminal type. When you change the L dimension the terminal changes from 'Outward L' to 'Gullwing'. The two have different goals.
lalexman
Posted: 12 Oct 2013 at 4:39am |
Ok. I did not realize the type of terminal changes depending on the pad length. Thanks! Again.
