  New Posts New Posts RSS Feed - PCB Model Select Radial (Dipped) Rect. 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: PCB Model Select Radial (Dipped) Rect. 1
    Posted: 12 Feb 2026 at 11:14am
For this part” 224MKP275KBG4” in this datasheet “"
Is it  “Radial (Dipped) Rect.”?  Correct or wrong,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 8:09am
This is the 'Radial (Disk) with Offset Leads'
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 12:39am
please add more details , as i noted
this radial Disk With offset Leads and it's Box Type (rectangular body) Not radial  and this Model not similar the shape of Part in Datasheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 11:47am
We recommend that if the Radial (Dipped) Rect. w/Offset Leads 3D STEP does not look correct, then build the footprint from scratch in FP Designer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:40am
you mean we can you Radial (Dipped) Rect for this part  For this part” 224MKP275KBG4” in this datasheet “"
please add more details why should use fp designer
This page was generated in 0.607 seconds.
