Gang Mask Applied on SC-75A
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: Gang Mask Applied on SC-75A
    Posted: 22 Mar 2022 at 7:02am
Hi to all,
I updated to PCBL 2022.04 and when I created a footprint for a small transistor (Vishay-SI1012CR)
I got the next message:
- Pads were trimmed to clear the body.
- Gang Mask Applied
I understood the message because the height A1(the min distance from the body to the pcb) was 0.0
I need help with the second message because I do not understand it... why?
I tried to attach a pic of it...
Thanks for you time and help.
Regards,
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 8:32am
Gang Mask is when you violate the minimum solder web rule.
You can change this in "File > Options > SMD Pad Stack Rules > Minimum Gang Solder Mask Web > 0.075".
By changing this value to 0.00 you turn off the feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 9:16am
Firstly thanks for your fast answer. Smile
But I think that I haven't violate any rule....
Anyway thanks for your time and help
Best regards,
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 10:10am
You are correct. The error message should not say "Gang Mask Applied".
This is a bug, and we'll fix it in the next V2022.05 pre-release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 2:49pm
Have you got a data sheet link to this part?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 11:49pm
Dear Jeff,
Sorry for the late reply, I am writing from Spain.....
The data I used was taken from here
I hope you used the same for analysis.
Thanks and regards.
dramos
This page was generated in 0.178 seconds.
