  New Posts New Posts RSS Feed - FPX File From POD Open in View Mode Only
wheels1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheels1234 Quote  Post ReplyReply Direct Link To This Post Topic: FPX File From POD Open in View Mode Only
    Posted: 19 Apr 2017 at 5:21am
Downloaded Diodes_ZXTR2005Z-13 from POD at it only opens if a viewer only. Will not open in editor
Now using 2017.11 and 2017.10 had the same issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:22am
That part was built in PADS and imported the p/d files into the FPX using File > Import PADS p/d
You cannot edit the part in Library Expert, but if there is a problem you can email us and we'll fix it ASAP.
If you want to edit the part to customize it, you have to do that in your CAD tool.
