  New Posts New Posts RSS Feed - FPX file clean-up split categories
caclark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Topic: FPX file clean-up split categories
    Posted: 22 May 2023 at 4:10am
I have been a user for nearly 10 years now. And in this time there have been many changes to the FPX (or whatever it has been named over the years). What I am running into now is that due to these changes. I have many categories that should be listed under just one. But instead I have anywhere from 2 to 10 separate ones for what should be the same category.
Is there a way to clean these up? I have pulled the FPX into Excel, and I know not to touch the first 5 columns. But I assume in one of these "untouchable" columns is where the problem lies with all these split categories.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 9:25am
In the Library Editor, you should run this feature -
Utilities > Regenerate Library > Physical Descriptions.
Let us know if that works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:05am
Tom,That certainly helped. But are still a few quirky ones that it didn't resolve. They seem to all involve the "(" and ")" being in different locations in the Physical descriptions. (see below screen captures of a few.)
For these oddball ones, are these able to be cleaned up by me just using a text tool like NotePad++?
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:24am
Ha Ha, the images didn't post for some reason. Let me try to add them again in a different way besides copy/paste into the message area (which showed just fine until I posted the reply).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:31am
We updated the FPX Physical Description from this
Quad Flat No-Lead (QFN with Tab), 0.40 mm pitch; 41 pin, square, 10 pin X 10 pin, 5.00 mm L X 5.00 mm W X 0.80 mm H body
To this
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; 41 pin, square, 10 pin X 10 pin, 5.00 mm L X 5.00 mm W X 0.80 mm H body
Reason was to make all component families similar (consistent) with SOP, QFP, etc.
If you notice the location of the Comma, that is where the "Categories" start before the comma.
This page was generated in 0.641 seconds.
