FPE Library Size |
jayfrancis
Topic: FPE Library SizePosted: 19 Jan 2023 at 1:22pm |
Going from Library Expert to Footprint Expert, my library size has dramatically increased (roughly 50K-ish to over 150M). Is this correct, or is something wrong with my library? I use GitHub to save/track my changes (I know - the fpx isn't optimized for that, but at least I can match it up with other files I change). Unfortunately, GitHub has a 100MB size limit :-( --Jay
Joined: 05 Jan 2012 Location: San Diego, CA Status: Online Points: 5993 |
Posted: 19 Jan 2023 at 1:59pm |
When your FPX library grows in size, it's mostly due to "Special Characters" as the FPX file is 100% ASCII.
Open your old FPX file in Excel spreadsheet and find out where the issues are. If you clean up your FPX file in Excel, you need to copy the contents to Notepad.exe to convert the data back to ASCII. But we can do that for you.
Send us your old FPX file and we'll check it. |
jayfrancis
Posted: 19 Jan 2023 at 6:33pm |
Thanks for your help Tom!
If anyone finds this thread - the culprit was a special character (TM symbol) in a component field. Tom was able to clear the error and bring the library back to a healthy state. --Jay
Ian S
Posted: 20 Jan 2023 at 4:22am |
Any chance you can add some code to check for special characters to prevent the FPX exponentially growing in size? I've seen the issue a couple of times and ended up with an FPX of >250 MB.
Jeff.M
Joined: 16 May 2012 Location: San Diego Status: Offline Points: 497 |
Posted: 20 Jan 2023 at 9:45am |
There is already code that's supposed to prevent that.
If you can provide an example of some text you've added to your fpx file that has caused your problem, we'll review the prevent code. Thanks for the report...
Ian S
Posted: 20 Jan 2023 at 10:11am |
Hi Jeff, If it happens again, I'll provide an example.
Can the code be expanded to check the FPX file for the existence of non-ascii characters when it's opened, and capture potential corruption, rather than just at data entry? Ian |
Posted: 17 Jul 2023 at 12:11pm |
The FPX file is ASCII.
"Symbol Characters" are not allowed in an ASCII database. Do not use any special Symbols like these: ® © ™ µ ± |
