  New Posts New Posts RSS Feed - 3D STEP Model TO-220AB
omar mahmoud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omar mahmoud Quote  Post ReplyReply Direct Link To This Post Topic: 3D STEP Model TO-220AB
    Posted: 01 Jan 2015 at 6:50am
How can I build 3D STEP model for TO-220AB?
I did not find a Package that fits.
Datasheet is - http://www.ti.com/lit/ds/symlink/csd19501kcs.pdf
Omar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 9:32am
Use the Through-hole > Flange Mount (TO-220) > Horizontal or Vertical.
There is one in the TH FPX file called - TO254P1590X1040X460-3
You can download the SM, TH and BGA FPX files that have over 5,000 Case Codes here - http://www.pcblibraries.com/account/user/memberdownloads.asp
You can also download the V2015.06 pre-release with the new 2015 Contour Courtyards for every component family.
Post Options Post Options   Thanks (1) Thanks(1)   Quote omar mahmoud Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 1:20am
Thanks for your reply.
I use TH FPX library but, there are difference between 3d-Model for "TO254P1590X1040X460-3" and TO-220AB Insulated Package  "http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00002264.pdf". by the way Mostly TO-220 is Straight package. Rarely it's Horizontal or zigzag(Vertical) check this document "http://focus.ti.com/en/download/qlty/MS101206-MISC.pdf"so, i suggest adding TO-220 Straight package in  Library Expert Pro 2015.06.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 1:19pm
The TO-220 Straight is already in the program called -
Flange Mount (TO-220) Vertical
