  New Posts New Posts RSS Feed - STEP file
STEP file
Hawk44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawk44 Quote  Post ReplyReply Direct Link To This Post Topic: STEP file
    Posted: 21 Sep 2013 at 7:44pm
OK, Finally down and made a part I had already made in Eagle.
A P485 SOIC 20 pin. So the program generated a step file.
I need a .SCR file for Eagle to use.
What did I miss?
Can you all give me a hint?
David  Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 7:46pm
The steps to output to any CAD format are listed under the Help menu (within the Library Expert) as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 7:53pm
I may have misread your question -- please make sure to specify an output file for both "Output Directory" fields. Do you have a valid path for both? Note the green marks are for the footprint, and the red for 3D STEP...
I assume you're using the latest 2013.13?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawk44 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2013 at 3:21am
Ok I admit I spent little time on setup. Including waiting to put the directory name in on the fly.
I'm going to go over the videos and written instructions carefully today. My fault, I just wanted to get up and running with a result to check as soon as possible.
I do have one question. Does Nick ever sleep?
I mean support here is great. I have always gotten answers here quickly. You guys have a passion for the project.
Thanks, be back soon Wink
This page was generated in 1.188 seconds.
