  New Posts New Posts RSS Feed - SIP Alignment
SIP Alignment
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: SIP Alignment
    Posted: 17 hours 4 minutes ago at 12:10pm
When did the direction of the E1 offset on SIP packages get flipped?
It bit me on a new design, where a regenerated footprint had a mirrored layout.
I think the new way is OK, I was just surprised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 16 minutes ago at 12:58pm
The E1 dimension is for the 'Offset' from the center.
If the pins are centered, do not enter a E1 dimension as it's Optional.
There is no SIP 'Mirror' feature in the current V26.07 release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 3 minutes ago at 7:11pm
The direction of the offset was flipped between 2025.04 and 2026.08. The same FPX gives different footprints. I was wondering when it happened.
--John
