  New Posts New Posts RSS Feed - Custom/arbitrary pad shape?
mdevoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdevoe Quote  Post ReplyReply Direct Link To This Post Topic: Custom/arbitrary pad shape?
    Posted: 28 Jan 2026 at 11:28pm
Is there any way to create an arbitrary pad shape for use in a pad stack?
I have a connector where the manufacturer recommended pads in the corners are "L" shaped. It's not a public part so unfortunately cannot share the datasheet.
I could realize this by splitting it into two rectangular pads, but thought I'd ask if there was any other option to natively generate a single pad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2026 at 9:05am
Footprint Expert cannot do irregular shaped pads, but we build those footprints in a CAD tool and import the ASCII data into FPX file.
What manufacturer and part number are you looking for?
Maybe the Case Code in already in the POD database.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdevoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2026 at 12:32pm
Appreciate the feedback and good to know that it's an option!
It's a unreleased, not yet publicly available part so I don't think it would be in the POD database. And unfortunately can't share drawings for it either.
I may just manually create it for now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2026 at 12:39pm
The best option is to build the basic pattern in Footprint Expert and then move it to your CAD tool to add the custom pad stacks.
Footprint Expert will auto-generate all the drafting outlines and create the standard pad stacks.
