  New Posts New Posts RSS Feed - Update Broken
Update Broken
 Post Reply Post Reply Page  123>
phil.holden View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Topic: Update Broken
    Posted: 18 Aug 2020 at 5:54am
After updating LE Pro to version 2020.01 I am no longer able to 'Add Footprint to CAD Library' as the button remains greyed out (i populated using Demo).
I have created the Cloud Activation Key and it is showing fine in my account.
Any ideas?
Answer Answer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 1:06pm
Please redownload 2020.01, the builds were updated that will very likely address your issue.
It is possible that you may need to re-enter your key after install.
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 6:59am
The V2020 release was enhanced.
Select "Help > Activate Cloud License
A Pro Key Activation Dialog Box will appear.
Select the Blue Dot with the ? to open Help / Instructions.
You login to your account and Copy/Paste the Activation Code Number into the Dialog Box.
Select "Save New" and all the features turn on.
There will be much better instructions coming today.
SDTKO View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote SDTKO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 8:04am
Hmm, that's exactly what I did and my "Add Footprint to CAD Library" button remains grayed out as well.
Post Options Post Options   Thanks (1) Thanks(1)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 8:20am
Yes i have been over it a few times now and there's a problem for sure....
The Installed Options in the client doesn't indicate which output is preferred. Despite showing as Altium Designer in my account settings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 8:24am
We'll get this fixed for you.
We'll send you an email with instructions and details.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 8:25am
Thanks Tom. Much appreciated.
Answer Answer
Nick
Post Options Post Options   Thanks (1) Thanks(1)   Quote SDTKO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 12:31am
Thanks guys. New build works as expected Thumbs Up
Post Options Post Options   Thanks (1) Thanks(1)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 1:06am
All working here now Nick. Thanks for your help.
JCurtis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCurtis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 10:08am
I downloaded the POD Builder 2020.01 (green button on the PCBL members downloads page) a few hours ago, and get the same issue as above.
I put the details as above into the POD program as in the details shown here https://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=310
I presume it's the POD builder version I need to use my existing POD credits?
