Molded Body 3D Step |
jmeinert
Topic: Molded Body 3D StepPosted: 14 May 2019 at 9:28am |
The molded body step file as an error or unclosed polygon that mentor graphic see as an error and will not open the file. When I open it in CREO it see the error but us unable to correct the problem
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6029 |
Posted: 14 May 2019 at 9:40am |
There are 2 types of Molded Body packages.
One follows the JEDEC DO-214D standard package where the "D" dimension is at least 0.80 mm larger than the "D1" dimension. The other Molded Body part where the Terminal Lead hugs the package and "D" and "D1" dimensions are less than 0.80 mm is a non-standard package and is not approved by JEDEC. We will address this issue in the upcoming V2020 release to allow the user an option to pick the type of package body that results in 2 types of Molded Body parts. However, if your "D" dimension is 0.80 mm larger than your "D1" dimension and you're still having problems, then send us the datasheet PDF or the URL link or post the mfr. name and part number here. |
jmeinert
Posted: 14 May 2019 at 11:43am |
Tom,
The explanation solved the problem. The AVX is not define the D1 dimension, so I made D1 = D. Changing D1 to equal D-.8 mm I am able to import the STEP file. Thanks, -Jeff
