  New Posts New Posts RSS Feed - Footprint using PCB
Footprint using PCB
rafiq234 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote rafiq234 Quote  Post ReplyReply Direct Link To This Post Topic: Footprint using PCB
    Posted: 10 Nov 2015 at 8:19pm
I am intend to buy PCB Library Expert. I am practicing using PCB Library Expert Lite.
All the component created all using Expert Lite are Nominal only?
How to create if we need Most or Least size using the Lite version?
Rafiq
Post Options Post Options   Thanks (2) Thanks(2)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 8:37pm
Select the "Terminal> Density Level" tab above the component dimensions.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 9:22pm
You can compare the Lite and the Professional here:
This page was generated in 0.578 seconds.
