Forum Home Forum Home > Libraries > Footprints / Land Patterns > P-CAD
    Posted: 21 Oct 2024 at 9:30am
  • IPC-7351B
  • IPC-7352
  • PCB Libraries (IPC-7351C)
  • Your Custom Footprint Name
Example:
QFN w/Thermal Pad
This page was generated in 0.672 seconds.
