Forum Home Forum Home > Libraries > Footprints / Land Patterns > OrCAD Layout
    Posted: 05 Jan 2025 at 6:32pm
Additional Considerations
Chip Capacitor
Chip Resistor
Chip Inductor
Polarized Chip Capacitor
Chip Diode
Chip LED
EIA (inch) Name
Inch Dimensions
IEC (metric) Name
Metric Dimensions
01005
0.0157 in × 0.0079 in
0402
0.4 mm × 0.2 mm
0201
0.024 in × 0.012 in
0603
0.6 mm × 0.3 mm
0402
0.039 in × 0.020 in
1005
1.0 mm × 0.5 mm
0603
0.063 in × 0.031 in
1608
1.6 mm × 0.8 mm
0805
0.079 in × 0.049 in
2012
2.0 mm × 1.25 mm
1008
0.098 in × 0.079 in
2520
2.5 mm × 2.0 mm
1206
0.126 in × 0.063 in
3216
3.2 mm × 1.6 mm
1210
0.126 in × 0.098 in
3225
3.2 mm × 2.5 mm
1806
0.177 in × 0.063 in
4516
4.5 mm × 1.6 mm
1812
0.18 in × 0.13 in
4532
4.5 mm × 3.2 mm
2010
0.197 in × 0.098 in
5025
5.0 mm × 2.5 mm
2512
0.25 in × 0.13 in
6332
6.4 mm × 3.2 mm
2920
0.29 in × 0.20 in
7451
7.4 mm × 5.1 mm
EXAMPLE 2 - Gullwing Leads:
  • Easily scalable
