  New Posts New Posts RSS Feed - Footprint Expert 26.03 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 26.03 Released!!
    Posted: 09 Mar 2026 at 11:08am
Version 26.03 was just released!!
Fixes & Enhancements:
  • 3D STEP:
    • Update Polarized Chip Capacitor
  • KiCad - terminal outlines are not registering correctly on the pads
  • FP Designer:
    • Adding a Paste Mask Layer to a through-hole pad stack for Pin-in-Paste added it twice in the Pad Stack Manager
    • BGA automatic alphanumeric pin numbers start repeating at 'BA' after 'BY'
    • When Drafting > Silkscreen > Allow Expanded Outline was turned off, the Save to FPX would not turn on
    • Remove the word Flat from the SON and PSON in Specifications > Description Category list
  • Library Editor:
    • Right Mouse > Add New Rows > 2. If you change the number of rows from 2 to 1 the program added 2
    • Utilities > Find Duplicate Part Numbers was displaying one less found item than reality
    • Remove the word Flat from the SON and PSON Physical Description in the FPX file
  • Options:
    • Pad stack name was adding redundant Mask pads shape identifier (C, R, etc.) if it is the same as the top pad shape
    • SMD Pad Stack Rules > Thermal Tabs
      • Added Thermal Tab Minimum Pattern to Pad Edge
      • Added ability to corner radius thermal pad paste mask apertures
    • The SOIC/SOP component family zero orientation was not communicating to the Calculator
    • Components > Surface Mount > DPAK > Thermal Tab Paste Mask Shape > 'Pattern' is the new default
  • Calculators:
    • Added reconciliation for 2 pin parts with dissimilar terminal sizes and tolerances (keeps calculation the same when pin locations are reversed)
    • Surface Mount > DPAK > Paste Mask – 'Simple' now follows the Paste Mask Reduction % set in Options
