Footprint Expert 24.11 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 24.11 Released!!
    Posted: 06 Sep 2024 at 2:50pm
Version 24.11 was just released!!
Fixes & Enhancements:
  • Options:
    • Components > FP Designer - removed the drafting outlines. All Drafting Outlines are now edited in the Drafting section.
    • Drafting - Every Outline is now consistent and has a "Add Outline To Footprint" switch that also turns that layer off in the viewer and the CAD tool
    • Drafting - The Centroid Crosshair and Origin are now separate entities that can be turned on/off separately
    • Terminals - Chip, update the Most Density Level for 0.75 - 1.35 from 0.05 to 0.00
    • File - Updated UI text for "New (Internal Defaults)" changed to "Use Internal Defaults"
  • Calculators:
    • Through-hole - Oscillator, removed drafting outline corner radius
    • 2-Pin DFN - Added a new LED component family
  • CAD Tools:
    • The main Header for Altium was updated to Renesas
  • FP Designer:
    • Updated the pad stack and pad names
