Footprint Expert 23.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 23.10 Released!!
    Posted: 31 Jul 2023 at 8:28pm
Version 23.10 was just released!!
Fixes & Enhancements:
  • Calculators:
    • Chip Array
      • 4-sided Concave/Flat – added Filter component family
      • 4-sided Concave/Flat – added the ability to change Pin 1 location
      • 2-sided Concave/Flat – added Filter component family
    • Molded Body & MELF – inserting Nominal height and tolerance generated the wrong height in the footprint name
    • Corner Concave Oscillator – added a provision for an expanded silkscreen outline
  • Options:
    • DPAK and DFN 3-Pin – added a feature to change the thermal pad paste mask from Solid to Pattern with 3 options
      • Automatic is a solid shape if the tab terminal extends beyond the body and has a toe; a pattern if the tab is only under the body
      • Simple is always a solid shape
      • Pattern is always a checkerboard
  • CAD Tool Interfaces:
    • Zuken CR-5000/8000 D-Shaped pads
    • KiCad now supports version 7
    • Allegro version 22.1 version selection not working
    • Altium – Save My Settings was not saving changes to the Mechanical Layer "Assembly Bottom"
This page was generated in 0.893 seconds.
