  New Posts New Posts RSS Feed - Footprint Expert 2022.09 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2022.09 Released!!
    Posted: 24 Jun 2022 at 4:44pm
2022.09 was just released!!
Updates & Bugs Fixed:
  • License:
    • Updated the HASP license to allow Footprint Expert to run as a Viewer if the HL or SL is are not found on startup or connection with key is lost
  • FP Designer:
    • Batch build FP Designer parts with an offset origin that caused the pins to move
  • Options:
    • Drafting > Component Outlines > turning off the “Output to CAD” turned the outline off in the viewer
    • FP Designer – Pad Stack Designer for Through-hole hole size calculations not synced with Terminal Options
    • Chip courtyard not sizing correctly for micro-mini parts
  • Calculators:
    • Removed the “SMD Pad Stack Rules” panel from all SMD Grid Array calculators.
