  New Posts New Posts RSS Feed - Footprint Expert 2021.09 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2021.09 Released!!
    Posted: 09 Jul 2021 at 12:29pm
2021.09 was just released!!
Updates & Bugs Fixed:
  • Drafting Options:
    • Added a new Right-Angle Triangle. This is mostly used for Pin 1 corner Polarity Marking.
  • Console Options:
    • IPC-7351B Naming Convention – in the SOIC component family, the program was adding an extra X after the pin pitch.
    • Master FPX File Name – when the master FPX file name was longer than 20 characters, the program was throwing an Unhandled Exception Error.
    • Pad Stack Rules – Gang Solder Mask Shape had a bug issue that affected solder mask shape on SMD pads.
  • Calculator Component Families:
    • All Grid Array’s (BGA, CGA & LGA) – setting the local Calculator solder mask in “Pad Stack Rules” panel does not work. A warning message was inserted prompting the user to set the solder mask swell in the “Terminal Density Level” panel.
    • All Through-hole Headers – When moving Headers to FP Designer and save to FPX, reopening the footprint dropped the Body Length & Width.
    • MELF:
      • When creating a Diode MELF, the local “Pad Stack Rules > Miscellaneous > Cathode/Anode Pin Names” was disabled.
      • When moving the MELF to FP Designer and save to FPX threw an error message.
    • Chip, MELF, Molded, SOD & SODFL Diodes - fixed Numeric/Alpha pin names and pin swap options on the right mouse button.
    • SMD Crystal – Physical Description had Body Length listed twice and no Body Width.
    • PQFN & PQFN w/Thermal – footprint name had wrong body length and width.
    • SOP w/Thermal – the Physical Description did not indicate w/Thermal Tab.
    • DIP and DIP Socket:
      • The Physical Description had the Length and Width swapped.
      • The Silkscreen Outline was not translating to any CAD tool.
      • When moving the DIP to FP Designer and save to FPX, reopening the footprint dropped the Body Width.
    • Flange Mount (TO) Horizontal – the Physical Description was missing the Body Length and the Pin Qty was incorrect.
    • Flange Mount (TO) Vertical – the Footprint Name and Physical Description had the Body Length and Width swapped.
    • All Through-hole families:
      • Pads and Holes on Assembly did not work properly.
      • Courtyard to Pad Excess was 0.45 and updated to 0.25.
  • CAD Tools:
    • KiCad – through-hole pad stacks had holes on assembly going to the fabrication layer.
  • Options:
    • Drafting > Silkscreen – changing the Reference Designator line width % was resetting back to 10% default when closing and reopening the program.
