Flex Circuit Footprint
chads108 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chads108 Quote  Post ReplyReply Direct Link To This Post Topic: Flex Circuit Footprint
    Posted: 20 Aug 2013 at 8:08am
I have a LCD that is to be connected to the PCB via a flex circuit soldered directly to the board.  The exposed pads on the flex circuit are 1.6mm x 0.6mm on 1mm pitch.  Is there some rule of thumb to use in determining the pad size to be used on the board to attach the flex circuit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2013 at 8:33am
I would recommend using the Most environment for the pad size and the Nominal environment for the solder mask size. This is a "Solder Mask" defined pad so that the solder mask helps to hold the pad to the flex board.
The solder mask only has to encroach on the Toe & Heel and not on the sides.
If you normally use the Least environment then make the pad size Nominal and the solder mask Least.
This page was generated in 0.093 seconds.
