  New Posts New Posts RSS Feed - Extended SOP Package Name
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Extended SOP Package Name
    Posted: 10 Sep 2013 at 8:00am
When you load a TI 16-pin PW package with the height and extended footprint names enabled the name that is created is SOP65P640X120-16L40L it s/b SOP65P640X120-16L
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 1:12pm
SOP65P640X120-16L40L is the correct name -
Small Outline Package, 0.65 mm Pitch, 6.40 mm Lead Span X 1.20 mm Height - 16-pins, Least Environment, 0.40 mm Nominal Lead Length
What is the problem?
(Tom responding from Melbourne Australia)...
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 1:16pm
Ok Did not realize that was the lead length. No Problem then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 1:21pm
It's the Gull Wing Lead Length as it determines the Pad Length.
So to eliminate duplication in all Gull Wing component families where the Gull Wing Lead Lengths vary in tolerances and lengths (when all the other dimensions are the same).
We'll move this post to the Q & A forum.
This page was generated in 0.734 seconds.
