  New Posts New Posts RSS Feed - Exporting settings
Exporting settings
rpcs0924 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote rpcs0924 Quote  Post ReplyReply Direct Link To This Post Topic: Exporting settings
    Posted: 24 Mar 2022 at 1:46pm
Hey All, is there a way to output your settings from 2021 and import them into 2022?  I just don't remember what I did going from 2020-2021.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 1:54pm
V2020 is the original legacy version. It used "Preferences" for the settings and an older FPX file format.
V2021 is a 100% rewrite of the code and User Interface and requires users to create a new "Options" file and translate the legacy FPX file to the new file format.
V2022 uses the same data files as V2021. Just copy the "Options" and "FPX" files and over to the new V2022 folder.
You can run V2021 and V2022 side by side until your files are copied over. Then you can uninstall V2021 if you want.
Post Options Post Options   Thanks (1) Thanks(1)   Quote rpcs0924 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 2:20pm
Thank you Tom!!
