  New Posts New Posts RSS Feed - Exporting Attributes/Info Into CADSTAR?
Mattylad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattylad Quote  Post ReplyReply Direct Link To This Post Topic: Exporting Attributes/Info Into CADSTAR?
    Posted: 27 Aug 2012 at 9:10am
A component I.E. DIODFN98X58X50-2
Has a physical description that is exported as a component attribute.
What about the case code etc?
Many users know their components by what you have as the case code and this would be ideal information to output.
As would the rest, so the ability to pick this information and export it as component attributes would be very handy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 9:57am
Library Expert only exports the Height and Description into all CAD Tools.
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 5:45am
QuIck answer there Tom :)
It could be nice if it could output the information entered into these separate columns as Attributes into
CADSTAR ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 6:51pm
It looks like that's it for the V2016 release.
Looking forward to V2017.
Maybe we can get this request in there.
Olaf.MuellerAE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Olaf.MuellerAE Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 6:21am
Last year was the information in will be come in 2016.
You moved it every year.
It was requested 4 years ago. And was it was previously available.
Export User Defined Attributes to CADSTAR should be come back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 7:15am
We would need some technical support from CADSTAR users to tell the programmers where in the CADSTAR ASCII Code does this information go.
We need several samples of existing parts with this information.
We're trying to support 23 CAD tools and all of their unique features. This is not easy unless someone provides samples and examples to help make the feature request possible.
Chris Arnold is Library Expert CAD tool interface programmer and you should direct all sample data to him.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 9:50am
I'll take a look at this. No promises.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 1:00am
Cheers Chris, let me know if you need any more information.
You should be able to export it in the same way you export the description and height as they come in as component attributes OK.
As much as it may be the plan for everyone to use the IPC naming convention - manufacturers still do not nor do I think they will - they continue to use the JEDEC names etc. so having this available is helpful.
This page was generated in 0.187 seconds.
