Explanation of Naming Convention
chads108 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chads108 Quote  Post ReplyReply Direct Link To This Post Topic: Explanation of Naming Convention
    Posted: 17 Sep 2014 at 1:49pm
I just created a footprint for a SOT23 and the resulting footprint name suggested is SOT95P230X120-3L18N.
I understand everything in that name except the L18 part.
I am assuming it is some reference to a dimension, but I sure can't figure it out in looking at the datasheet.
What is that referring to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2014 at 1:57pm
You have the "Extended Footprint Names" turned on in User Preferences.
The L18 = the Lead Tolerance for a Gull Wing lead form.
The lead tolerance impacts the pad length. A lead tolerance of 0.18 mm is good, but some Gull Wing leads have a tolerance of 0.60 mm to 0.90 mm and that makes a big difference in the pad length.
Without the extended names for gull wing, the IPC-7351 calculator would auto-generate a duplicate footprint name even though the pad lengths could vary in length.
I'll bring this to the attention of the IPC-7351 land pattern committee on Wednesday October 1st in Chicago, IL.
