Error in J-Lead Step-Models? |
ronald
Thanks(1)
Topic: Error in J-Lead Step-Models?Posted: 15 Nov 2018 at 5:45am |
Hello, I tried to generate a Step-Model for a SOJ Part with this settings: ![]() And thats what I got as Step-Model: ![]() Am I doing something wrong or is this an error in Library Expert? I´m using Library Expert Pro 2018.07 Thank you, Ronald Edit: I just tired Version 2018.08 and got the same result.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Online Points: 6029 |
Thanks(1)
Posted: 15 Nov 2018 at 8:13am |
There are several things that are wrong.
ronald
Thanks(1)
Posted: 15 Nov 2018 at 8:47am |
Sorry, I´m talking about this part: https://support.epson.biz/td/api/doc_check.php?dl=brief_RX-8035SA&lang=en The height is actually wrong, I must have mistyped it, when I did the screenshot. But I get a similar result, when using the using the correct 1.2mm. I only need the Step-Model, so I didn´t bother to type in the tolerances. The SOL Packge doesn´t offer a 12 Pin Version.
Thanks(1)
Posted: 15 Nov 2018 at 8:51am |
That is a Small Outline L-Lead (SOL).
And the package Height is 1.20 mm (not 0.50 mm). |
ronald
Thanks(1)
Posted: 15 Nov 2018 at 9:08am |
As i worte there is no 12 pin version of the SOL Package.
Posted: 15 Nov 2018 at 9:19am |
OK, we'll add a 10 and 12 pin version in the V2018.09 pre-release ASAP.
ronald
Posted: 15 Nov 2018 at 9:32am |
Cool, thank you!
Nick B
Posted: 15 Nov 2018 at 11:00am |
Please get the 2018.09 pre-release from www.PCBLibraries.com/Downloads, it has new updated feature.
Nick B
Posted: 15 Nov 2018 at 11:01am |
NOTE: only the Enterprise version is released in pre-release. If you're using the free version(s), this won't be available for another 2-3 weeks.
