  New Posts New Posts RSS Feed - Error in J-Lead Step-Models?
ronald View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ronald Quote  Post ReplyReply Direct Link To This Post Topic: Error in J-Lead Step-Models?
    Posted: 15 Nov 2018 at 5:45am
I tried to generate a Step-Model for a SOJ Part with this settings:
And thats what I got as Step-Model:
Am I doing something wrong or is this an error in Library Expert?
I´m using Library Expert Pro 2018.07
Thank you,
Ronald
Edit: I just tired Version 2018.08 and got the same result.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 8:13am
There are several things that are wrong.
  1. The footprint is generated by the package dimensions and Tolerances and you did not insert the tolerances
  2. There is no such thing as a 0.50 mm Height SOJ package. The average Height is 3.55 - 3.79 mm
  3. There is no such thing as a 0.50 mm Pitch SOJ. SOJ is a 1.27 mm pitch part
  4. Your package may be a SOL package and you picked the wrong component family
  5. You did not post a URL link to the component datasheet, so there is little we can do to help you
Post Options Post Options   Thanks (1) Thanks(1)   Quote ronald Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 8:47am
The height is actually wrong, I must have mistyped it, when I did the screenshot.
But I get a similar result, when using the using the correct 1.2mm.
I only need the Step-Model, so I didn´t bother to type in the tolerances.
The SOL Packge doesn´t offer a 12 Pin Version.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 8:51am
That is a Small Outline L-Lead (SOL).
And the package Height is 1.20 mm (not 0.50 mm).
Post Options Post Options   Thanks (1) Thanks(1)   Quote ronald Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 9:08am
As i worte there is no 12 pin version of the SOL Package.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 9:19am
OK, we'll add a 10 and 12 pin version in the V2018.09 pre-release ASAP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronald Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 9:32am
Cool, thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 11:00am
Please get the 2018.09 pre-release from www.PCBLibraries.com/Downloads, it has new updated feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 11:01am
NOTE: only the Enterprise version is released in pre-release. If you're using the free version(s), this won't be available for another 2-3 weeks.
