  New Posts New Posts RSS Feed - Editing  a footprint and saving to a diff library
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Topic: Editing a footprint and saving to a diff library
    Posted: 14 Mar 2014 at 1:05pm
So I open your SM library.  I select a part (line), copy, close the library, open my own, and past that line in.  Then I take that component's dimensions and modify to suit a different manufacturer.  I change the name, data sheet link etc., etc.  Then I hit 'OK', and then I save the library.
If I look at something else in that library or at another library and come back to that same line, the changes I thought I entered are not there.
What are the exact steps to copy, edit and save the modified copy to another library?  I assumed build will come later when I have made all the changes I want so that I do not have to do them a part at a time for my target tools.
Its these real elementary videos that are missing.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2014 at 3:06pm
When you edit component dimensions, you MUST save those back into the FPX file.
  1. Open part in Calculator
  2. Change dimensions
  3. In the Library Manager (FPX), select the Gray Box to the left of the Footprint Name to highlight the entire row
  4. Select the Import Part icon in the toolbar
  5. A dialog box will appear and ask you if you want to update existing library part
  6. Select "Yes" and the program will update all the component dimensions for the new part
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2014 at 3:48pm
So to move the part to MY fpx as desired, first I copy and paste the part to my library.  Then go through the above steps to edit and import it.
Copy, edit and import it first to my fpx, ....then save my fpx.
