  New Posts New Posts RSS Feed - Eagle CAD tool: Rectangle Converted Into Square
Bharat_Verma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Topic: Eagle CAD tool: Rectangle Converted Into Square
    Posted: 21 Nov 2022 at 2:14am
One more issue with rectangle pads becoming square in Eagle output files.
See the pin 1 in below Image.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2023 at 8:39am
Can a sample of the proper format for an oblong and rectangular through-hole in an Eagle scr please be provided?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 9:45pm
Hi Jeff ,
Please find attached .lbr and .fpx file for your reference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 12:40pm
Was this fixed? Please confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 3:29pm
Please provide an example of both an FPE translation to Eagle .scr file that is wrong and another version of that same file that has been edited correct this error.  That will allow us to compare and correct the discrepancy.
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 1:01am
Hi Jeff,
Please find attached zip file with FPX, LBR and SCR file.
This issue is not resolved in version 23.09.uploads/15710/Rectangle_pad_Version-9.zip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 3:04am
Hello Team ,
Any news on reported issue ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2023 at 12:35pm
The latest V23.11 is released – www.pcblibraries.com/downloads
Download and install it.
This issue with the rectangular pad shape coming into Eagle as a square is fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 8:47am
Eagle can't create a rectangle pad on a through hole.
