  New Posts New Posts RSS Feed - DPAK with T-shaped Tab
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: DPAK with T-shaped Tab
    Posted: 16 Dec 2016 at 7:23am
I'm making footprints for some JEDEC TO-263 (D2PAK) packages. In a number of the variants, the thermal tab increases in width above the body of the part.
My concern is that if I set E1 to the narrower dimension of the tab, it will solder okay, but the 3D model, courtyard, and outlines will be incorrect.
If I set E1 to the widest extent of the pad, the pad will be swimming in solder and won't self center.
How have other people dealt with this? (I'm currently evaluating PCB Library Expert to see if it's better than the built in functionality of Altium.
I'm hoping for a solution where standard packages don't require hand tweaks.)
--John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 7:28am
All irregular shape pads are done internally at PCB Libraries in PADS Layout and then we add that data to this folder on your computer -
C:\Program Files (x86)\PCB Libraries\Library Expert 2017\Libraries\PADS to CAD
Watch this video of the Tool Box. You only need to watch the first minute.
