Do We Have a New Release of IPC-7351C? |
Page <1234> |
dramos
Posted: 30 Nov 2022 at 11:19pm |
Dear Tom,
Many thanks for the info. A part of the modification of the value of the Fabrication and Assembly tolerances, is there other modification on the pad's calculation formula? If the main modification is this I consider that it is a minor change because you wrote many times that these values could be changed to 0.00 due to the accuracy of the new machines. I can't wait the Footprint Expert V23 to check the changes. Regards, David
SDTKO
Posted: 01 Dec 2022 at 4:04am |
Where can I find the IPC-7352 option file? My installation folder appears to only contain an IPC-7351C.opt file (FPE Enterprise 2022.14).
dramos
Posted: 01 Dec 2022 at 4:14am |
Hi SDTKO,
Tom in his last response speaks about V23... I think that we must wait until the new version is ready. Regards, dramos
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6074 |
Posted: 01 Dec 2022 at 8:56am |
The IPC-7352.opt file is located in the main installation folder:
C:\Program Files (x86)\PCB Libraries\Footprint Expert 2022 |
dramos
Posted: 02 Dec 2022 at 12:13am |
Dear Tom,
Which version of Footprint Expert are you using? I have just installed 2022.14,11/8/2022 and I am not able to find that file. ![]() Regards, david
Nick B
Posted: 02 Dec 2022 at 9:42am |
It looks like you're missing most of the other files too. Try to reinstall.
Could be some security software is interfering with the installation, maybe? Not counting the folders, you should have about 20 files in this folder, you have far less than that.
Posted: 02 Dec 2022 at 10:17am |
I'm using V2022.15 pre-release.
Note: V2022.15 will be officially released this weekend. It will be the last release this year. |
acastro
Posted: 05 Dec 2022 at 10:26am |
In this thread, I see that the .opt for IPC-7352 should be there when installed, but I don't see it show up after installation. Thank you.
Posted: 05 Dec 2022 at 10:29am |
What Footprint Expert version are you using?
Nick B
Posted: 05 Dec 2022 at 10:54am |
Please download and use the latest build.
Page <1234> |
