  New Posts New Posts RSS Feed - Do We Have a New Release of IPC-7351C?
 Post Reply Post Reply Page  <1 234
cgnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cgnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 3:13pm
Is IPC-7352 intended as the replacement for IPC-7351B? Or is IPC-7352 intended to be used with IPC-7351B? As someone who is not involved with the development of these standards, it's a bit confusing trying to understand exactly what the differences between these two are.
The reason why I'm asking is because some other IPC standards use a "series" naming convention (e.g. IPC-6010 series with 6011, 6012, etc), where new revisions of each document use A, B, C, instead of changing the base document number.
However, in the case of IPC-7352, it seems like the revision naming went IPC-7351A -> IPC-7351B -> IPC-7352 for some reason. If IPC-7352 is intended to supersede IPC-7351B, does anybody know why they didn't just name it IPC-7351C for consistency?
Is there a description posted anywhere that details the changes/additions in IPC-7352 vs. the existing IPC-7351B doc? I haven't purchased IPC-7352 yet, and I'm trying to understand what the new standard includes that caused it to change the base document number instead of just going to rev C.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 5:05pm
The main reason why IPC-7352 replaced IPC-7351B is because 7352 includes Through-hole technology.
IPC-7351 was 100% Surface Mount.
The 7352 Naming Convention was expanded to include additional information like Thermal Pad size and other missing package data.
IPC-7352 is not a Standard. It's been downgraded to a guideline
The real "Standard" for solder joint goals is IPC J-STD-001 Requirements for Soldered Electrical and Electronic Assemblies and it covers both Surface Mount and Through-hole technology.
