  New Posts New Posts RSS Feed - Display 2D & 3D Components With Maximum Body
jlara View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlara Quote  Post ReplyReply Direct Link To This Post Topic: Display 2D & 3D Components With Maximum Body
    Posted: 04 Jul 2016 at 2:22pm
Altium displays the components with maximum dimensions of the body created by Library Expert Lite 2015, but Library Expert Lite 2016 and LE Pro 2016 only display nominal dimensions for 2D and 3D Model.
Therefore, is it possible to export the 2D & 3D model with the maximum dimensions of the body using Libray Expert Pro 2016?
Thanks & Regards,
Juan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 2:31pm
You can output 3D STEP models in Minimum, Nominal and Maximum material condition.
In the Build Part or Library UI in the lower right corner, make your selection and Save As Preference.
